a track input idea,
when you select a track as an input to another track with the "virtual input" combobox at the top of each track and the incoming track contains more than one output, only the first output is received in the receiving track. Is there a way to allow all outputs to be utilized from the track input selection? maybe by summing them all together?
track virtual inputs
Actually, I just noticed the "mixer" modules within the "big mixer" patch in the library. This makes my request possible at patch level. Please disregard the above post.
actually I was wrong. this module also only outputs the first stereo pair of the track as well. I suppose I could just build this scheme using busses. thanks anyway.
More generally, we have to retain the idea to have an input as a mix on several audio sources.
I know how to implement it but it's a long way...
