Audio splitter
martignasse
i'm on the way to make a specialized and simplified matrix version : matrix - Audio Mixer
- X in, Y out
- mono or steteo
- on/off and fade mode.
mixer and splitter all in one, it should do the trick
- X in, Y out
- mono or steteo
what about an audio matrix that create wires in/out when cellz are on too? will try that..
ie 8x8, if swich on cell 2-4 it create a link between audioIn2 to audioOut4 ect.
matrix audio mixer !
martignasse
it's will be exactly that with the on/off mode23fx23 wrote:what about an audio matrix that create wires in/out when cellz are on too? will try that..
for the fade mode, it will be like an audio mixer, but with multi in and multi out
you'll have the choice off how many audio in and out with the query system at module creation ( 2 in - 2 out, 2 in - 4 out, 4 in - 4 out...)
will be very simple (immediate use, no patch needed) and powerful
so basicly an audio routing matrix, correct? This is something we've needed for a long time!
martignasse
yep, now that the generic matrix (next version 1.2) is kind of mature, i can make simplified and specialized version very easelygurulogic wrote:so basicly an audio routing matrix, correct? This is something we've needed for a long time!
hi martignasse
I'm very intersted by audio matrix
When shall we hope this wonder ?
martignasse
...sorry for response delay... i'm quite busy on other things for now (3D online stuff
like i said, it's on the way... but no release date for now...
about 2011, first quarter, something like that.
can't be more accurate
Ok thank you for the answer.
Before april would be cool !
Users browsing this forum: No registered users and 29 guests
