'patch cable' removal
- senso
In the next version you will able to select a wire and delete it.
jean-marc duchenne
And perhaps also the possible use of the Delete key together with actual Ctrl+X to delete a module ?
And what about the lasso selection of modules with a modifier key ?
Habits, habits...
Habits, habits...
- senso
I know that I should improve all the editing functions (group select, wire select/delete, shift+select, etc)
I'm working on
I'm working on
- senso
In the 1.019 version, I add the possibility to select a wire and delete it. It's the first step to a general improvement of the interface.
My next goal is the "multiselect" (with shift or ctrl)
jean-marc duchenne
Always waiting for it..................................................................................lvr wrote:+100 !And what about the lasso selection of modules with a modifier key ?
multiphone
Yes !
I sign the paper.
But, it's probably harder to do than i think.
Best
I sign the paper.
Best
