conductor lite all visible
Alain Vankenhove
Unread post by Alain Vankenhove » 21 Sep 2010, 13:59
my suggestion is simple. What do you think to place conductor lite on the right of the console, all the time visible,
Alain,
Trumpet player
A7C
TC Konnekt 24 D
MPD 24
AXIOM 25
BCR 2000
FCB 1010
Asus A7C dual core/RME Fireface UC/Axiom 25/MPD 24/Trumpet/BCR2000/FCB1010
Unread post by bsork » 21 Sep 2010, 14:10
Wouldn't that be rather annoying for those that don't use it?
Unread post by senso » 21 Sep 2010, 19:00
you have the auto-show option in the conductor lite.
also the window position is memorized.
I'm sure it will do the trick!
Unread post by woodslanding » 21 Sep 2010, 19:03
like the sequencer is annoying if you don't use it??
I think a nice suggestion would be to allow the toolbar to be customized, like most other software (word, photoshop, etc)......
On my monitor, there would be plenty of room for the conductor. But I don't really need it either.
-e
Unread post by bsork » 21 Sep 2010, 21:46
woodslanding wrote:like the sequencer is annoying if you don't use it??
Point taken - sorry...:/
But aside from what Senso has already mentioned: As you can create your own personal interface for just about anything in Usine, is there really any need for customizing the standard GUI?
Unread post by woodslanding » 22 Sep 2010, 06:35
bsork wrote:But aside from what Senso has already mentioned: As you can create your own personal interface for just about anything in Usine, is there really any need for customizing the standard GUI?
probably not ;)
Although somebody just asked for it.....
For me, I wish I could change the conductor layout. I write presets in live performance, and the lettering is so VERY small..... and there is no other place or way to name presets, right?
Until we get an 'EditableTextfield' module and a 'current preset name' input on the conductor module.....
Alain Vankenhove
Unread post by Alain Vankenhove » 23 Sep 2010, 21:43
The idea most interesting for me would be to allow the toolbar to be customized sequencer and /or conductor, like suggest woodslanding. Whatever you do it's your interface, composer music, just improvising ... in each time it's not the same applications, the same needs.
Unread post by senso » 23 Sep 2010, 22:37
As said bsork you can recreate almost all the interface of Usine with "/interface control/Usine panel" modules.
I prefer this solution than hard coding into Usine itself.
It's more flexible even if it's can be harder.
Users browsing this forum: No registered users and 59 guests
