Audio splitter
gurulogic
Unread post by gurulogic » 15 Jul 2010, 11:01
An audio splitter just like the audio mixer in reverse, with array mix values. I think this would be usefull?
martignasse
Unread post by martignasse » 15 Jul 2010, 18:25
i'm on the way to make a specialized and simplified matrix version : matrix - Audio Mixer :)
- X in, Y out
- mono or steteo
- on/off and fade mode.
mixer and splitter all in one, it should do the trick ;)
Unread post by 23fx23 » 15 Jul 2010, 20:22
what about an audio matrix that create wires in/out when cellz are on too? will try that..
ie 8x8, if swich on cell 2-4 it create a link between audioIn2 to audioOut4 ect.
Floego
Unread post by Floego » 15 Jul 2010, 20:25
matrix audio mixer ! :cool:
martignasse
Unread post by martignasse » 15 Jul 2010, 21:13
23fx23 wrote:what about an audio matrix that create wires in/out when cellz are on too? will try that..
it's will be exactly that with the on/off mode
for the fade mode, it will be like an audio mixer, but with multi in and multi out
you'll have the choice off how many audio in and out with the query system at module creation ( 2 in - 2 out, 2 in - 4 out, 4 in - 4 out...)
will be very simple (immediate use, no patch needed) and powerful
ethnix73
Unread post by ethnix73 » 15 Jul 2010, 22:10
Yeah! :cool:
Seb.Dub
Unread post by 23fx23 » 16 Jul 2010, 00:24
wow that sounds very cool martin! well done
gurulogic
Unread post by gurulogic » 16 Jul 2010, 02:14
so basicly an audio routing matrix, correct? This is something we've needed for a long time!
martignasse
Unread post by martignasse » 16 Jul 2010, 17:53
gurulogic wrote:so basicly an audio routing matrix, correct? This is something we've needed for a long time!
yep, now that the generic matrix (next version 1.2) is kind of mature, i can make simplified and specialized version very easely
Unread post by 23fx23 » 17 Nov 2010, 22:50
yes, and on the matrix perf update :) ?
joffo78
Unread post by joffo78 » 21 Nov 2010, 13:17
hi martignasse
I'm very intersted by audio matrix
When shall we hope this wonder ?
martignasse
Unread post by martignasse » 23 Nov 2010, 23:41
...sorry for response delay... i'm quite busy on other things for now (3D online stuff :))
like i said, it's on the way... but no release date for now...
about 2011, first quarter, something like that.
can't be more accurate :|
joffo78
Unread post by joffo78 » 24 Nov 2010, 07:31
Ok thank you for the answer.
Before april would be cool ! :D
Users browsing this forum: Google [Bot] and 15 guests
