Randomize
lalo
Unread post by lalo » 18 May 2006, 19:46
hi guys,
would be nice to have a general randomizer that works on the patch level...
kind of...
you open a list that shows all the parameters present in a patch (VST plugins included)
and then you select wich parameters you wnat to be randomized...with seed options..range options etc..for every parameter :)
lemme know what you think about :)
Unread post by senso » 20 May 2006, 11:14
This option could be funny. Like in Reaktor, or Buzz?
I could add a new field in the parameter of "design modules" witch could do this behaviour.
lalo
Unread post by lalo » 20 May 2006, 11:16
great...some randomness sometimes is a good inspiration :)
i c(age)hing :)
lalo
Unread post by lalo » 28 Feb 2007, 12:50
hi,
just to bump it a little :)
a randomizer window in wich you can choose the parameters in the patch you want to randomize (and in wich min max range of parameter value)
would be nice to have it at the VST shell level without the need to connect sliders to all the (sometimes a lot) vst parameters...this could be a great preset generator
another great ide would be to have a tablet object in wich you can create points that rapresent a patch preset....
sou you could morph between patch presets obtaining great morphing textures
thanx
Unread post by senso » 28 Feb 2007, 16:43
hello, thanks for your feedbacks
It's a good suggestion, but an hard job...
yes, something like the XY panel, and move the cursor to make cross fades between presets.
lalo
Unread post by lalo » 01 Mar 2007, 09:51
senso wrote:It's a good suggestion, but an hard job...
hope you'll find the time to do it in the future :)
senso wrote:yes, something like the XY panel, and move the cursor to make cross fades between presets.
exactly..and on the XY panel creating different points rapresenting the presets..
would be nice to include or exclude patch parameters and how much they are influenced from the morph process
lalo
Unread post by bsork » 02 Mar 2007, 08:49
Well lalo, you got me thinking and it occured to me that an XY pad that morphs between 4 different sets of parameters is fairly easy to implement in Usine except for one thing: The math needed to calculate the output values.
I'm working on it, but if there's someone out there who knows the correct fomula, I would very much like to have it.
Unread post by senso » 02 Mar 2007, 09:04
I think lalo needs interpolations between presets (a set of many value).
For the formula.
Too early.
I need a coffee.
lalo
Unread post by lalo » 02 Mar 2007, 09:15
senso wrote:I think lalo needs interpolations between presets (a set of many value).
exactly
senso wrote:For the formula.
Too early.
I need a coffee.
yes :)
good morning
Unread post by bsork » 02 Mar 2007, 13:38
I think I've found the formula. I was thinking way too complicated in the beginning. I think I'll post something in Add-ons. During the weekend, maybe.
moody33
Unread post by moody33 » 12 Jul 2007, 00:22
antispam message!
