linux
lalo
Unread post by lalo » 02 Aug 2008, 14:04
hi guys!
i know ..i know....usine is not intended to work with linux...
but anyway i did some tests on ubuntu studio with wine and wineasio installed (reaper and vst plugins work just fine on linux here!!!yeahh)
usine loads only if you double click on the usine exe inside the files folder and not the main usine.exe one....
it does'nt see the asio driver and its video refresh is damn slow...
...just to let you know
usine roxxxx!! hope we will see it in linux (lower latency in linux here than windoes!!!
lalo
Unread post by senso » 02 Aug 2008, 14:46
ha linux!!!
Never really tested but I imagine you can have a lot of troubles!
If I have time I'll try as soon as possible.
