http://www.simulus.org/p5glove/
I've been using the P5 glove to control plug-ins and Usine via midi,
but I just remembered the OSC version...
Anyone tried this?
p5 glove controlling Usine via OSC?
normally it should work if you have a way to convert P5glove info into osc mesages.
Are you sure the convertor exists for windows
was that a question?
"P5 Glove MIDI (April 21 2004) for Windows by Ross Bencina converts P5 glove data into MIDI."
same guy who announced the Wiimote VST made a kewl GUI for P5:
http://acousmodules.free.fr/acousmodule ... processors // P5 Control
http://acousmodules.free.fr/acousmodule ... processors // P5 Keyboard
yes it was a question !
now I have the answer...
Jean-Marc does a really great job with his accousmodules.
Indeed, I use them all the time.
I don't think I worded my question correctly...
I use it for midi using Jean-Marc's plug-ins, I'm just wondering if anyone has used the OSC version in Usine? I've never had much OSC-compatible software to play around with
I don't know. The only thing I know is that OSC works fine (I use it with a lemur).
Users browsing this forum: No registered users and 502 guests
