Page 1 of 1
Posted: 25 Jun 2008, 15:13
by cybercharles
Hi
Is it normal that USINE don’t work whit INTERNAL SOUND CARD ? Only with ASIO DRIVER.
if no, any suggestions ?
My stuff: MACBOOK PRO 2.2GHZ,OX10.5.3, with Boot Camp updated on 2.1, windows XP SP2.
My internal sound card is a Realtek whit the last driver from 2008.
Regards
Charles
Posted: 25 Jun 2008, 15:39
by nay-seven
on pc here the solution :
http://www.asio4all.com/
don't know if it work on boot camp....
Posted: 25 Jun 2008, 16:11
by cybercharles
Hi thanks for this answer but this not what exactly I want to know.
I know about ASIO4All. But with my RME firface i don't have any problems using USINE with ASIO drivers and all the other software (windows media, audacity, B4 VSTi, ….) manage to use the internal sound card without ASIO4all or any other stuff …
To be more precise, my question is:
Is it normal that my Internal sound card is not recognized in the USINE control panel?
regards
Posted: 25 Jun 2008, 16:58
by nay-seven
yep , it's normal cause Usine works only with asio driver
( check manual : Hardware & Software requirement : An Asio sound card compatible or a WDM sound card with the universal Asio driver
Asio4all available at http://www.asio4all.com/. )
sorry if i was'nt enought clear..
Posted: 25 Jun 2008, 17:41
by senso
Don't cry Charles, generally WDM drivers aren't suitable for live music, because of the latency.
I use Usine on a mac book with Asio4All: no problem.
Posted: 25 Jun 2008, 17:51
by cybercharles
thanks !
