Show Usine
Vincent
Unread post by Vincent » 29 Apr 2008, 01:01
Show Usine. It's in the title and in the global remote...
Did anyone try this funny joke?
vincent michel
composer & novelist
Unread post by senso » 29 Apr 2008, 17:41
it's not a joke: in the vst version you can make a midilearn on it and show/hide Usine with a midi control.
It can also be useful if you have several audio apps running at the same time...
I use it!
Vincent
Unread post by Vincent » 29 Apr 2008, 21:30
Yes, for VST version of course...
But for standalone, it hides the task and you cannot make it visible any more (except writing a few code lines in Visual Basic or other...), when you forgot saving the workspace before! That was funny!
vincent michel
composer & novelist
