Back for few minutes
Vincent
Unread post by Vincent » 05 Mar 2008, 04:54
Hello guys,
As I can see, Usine is working hoter than ever.
I work with the last release since a small week, well, what to say?
I'm really impressed by all the developpements, including the "live" help.
I think that Usine is the music soft that gives the more power for creativity. You can just patch anything you think about, surely anything.
Just drop an envelope follower and a good convolution plugin (with no latency), and connect the envelope follower to the early reflexions color and calculate some short delay variations, you make real space with small velocity changes... Then use the same envelope follower and some math modules to tweak the surround panner... Then drop your notes in the space, close, far, very far. That soft is just incredible.
Olivier, you were once discussing about genius, saying: "me? oh, no..."
Yes, you are.
Bye, I have to go back to my kilometers of wires.
vincent michel
composer & novelist
Unread post by senso » 05 Mar 2008, 10:03
thanks,
But I'm far to consider myself as a genius!
Just open my ears and try to implement all your suggestions try to understand what you need.
And ... hard work...
That all!
