Page 1 of 1
Global array as preset system
Posted: 23 Oct 2025, 20:53
by oli_lab
I am making a wild OSC interface with quite a bunch of RGBW Led's so I figured out a sleak way to command these Led's.
It's a Global Array based preset system. (GA string)
the LED color settings (+ dimmer, blinker...) are written in a global array.
Then, Usine can read the table to set any LED, so a preset list can be used in multiple instances.
I did a patch for DMX fixtures so you can try this method !
Enjoy !
DMX and global array.wkp
Re: Global array as preset system
Posted: 24 Oct 2025, 10:34
by grego mondo
Nice, thanks.
I like the "already existing option" (this pst already exist so I won't save it)
I 've just discover "display line number" in the listbox options, can be usefull and save some brain ;-)
Posted: 26 Oct 2025, 09:20
by oli_lab
sharing is wealth !
