Page 1 of 1
Wavetables
Posted: 22 May 2025, 15:59
by Gilsornette
Where can I find wavetables to use with Oscillator Wavetables? Or what kind of software may I use to create some?
Thank you!
Re: Wavetables
Posted: 24 May 2025, 15:57
by oli_lab
an online tool and repository : https://www.carvetoy.online/
and offline tool : https://audioz.download/software/win/11 ... eware.html
Re: Wavetables
Posted: 24 May 2025, 18:10
by Gilsornette
Thank you very much!!
Re: Wavetables
Posted: 24 May 2025, 19:25
by Gilsornette
I've loaded wavetables as wave files but when I change the frequency I've got strange results: non linear response, inconsistent, and not following the frequency curve.
As the recording attached. What am I missing?
Re: Wavetables
Posted: 25 May 2025, 00:05
by oli_lab
try the module from Oli_lab, it is more compliant with different wavetables ans has a interpolation option for smooth transitions between waves !
Re: Wavetables
Posted: 26 May 2025, 10:37
by Gilsornette
It works fine with this module. Thank you!
Re: Wavetables
Posted: 05 Jun 2025, 19:29
by oli_lab
I checked the code for the module and there is an alogo to cater to different format of waves :
if its a PPG wave, it's less than 32768 samples and divided in 64 one-cycle waveforms, otherwise, if it's bigger its divided in 256 one-cycle waveforms.
I'm working on a new version of the wavetable module with more tweaks !
Re: Wavetables
Posted: 06 Jun 2025, 19:18
by oli_lab
I fixed a bug in the wavetable reader V2 module and made a V3 pretty much improved !
need to update the modulilab and oliloscope addons.
check the example here :
wavetable reader V3.wkp
enjoy !
Re: Wavetables
Posted: 07 Jun 2025, 15:56
by Gilsornette
Thank you! These are indeed nice improvements!
Re: Wavetables
Posted: 08 Jun 2025, 19:59
by cmodica
I'm trying to test “wavetable reader V3.wkp”, but I can't get it to load properly.
I have updated HH to the latest version and I have also updated modulilab and oliloscope addons.
Some files seem to be on a Dropbox and I don't know where to redirect HH to find them ...
I am attaching a screenshot of one of the missing files, there are several.
Thanks for the help.
See you soon.
PS: I'm on MAC Intel OS 10.14.6
Re: Wavetables
Posted: 08 Jun 2025, 21:20
by oli_lab
ho sorry for that !
the wavetables are located in the modulilab/oscillators folder within the addons.
Re: Wavetables
Posted: 09 Jun 2025, 10:41
by cmodica
But where is the addons folder on mac os ?
:roll:
Re: Wavetables
Posted: 09 Jun 2025, 11:24
by grego mondo
Once updated the addons (and restarted Usine) there was no more question from computer for me, Usine figured by his own where was that (on PC)
Re: Wavetables
Posted: 09 Jun 2025, 12:25
by cmodica
This is not the case on my Mac OS 10.14
Re: Wavetables
Posted: 09 Jun 2025, 18:12
by oli_lab
Not very fluent with MACOS, only fire the mac mini to compile the user modules !
As I understand, all the things Usine are in the Usine folder in the app folder.
You may do a search for "wavetables" as its the name of the folder I put them in.
Tell us when it's OK
Re: Wavetables
Posted: 09 Jun 2025, 19:31
by cmodica
Hi and thank you.
It works.
The Addons folder and all the files needed on Mac OS X are in the Usine folder/contents/Config/Addons/
Thank you for this great wavetables synth. Great job !!
