I've just installed this on a new Macbook Air on macOS 14.4.
I've copied all my previous setup files from Config folder to the new one.
Workspace loads just fine, audio routing and midi settings are just there, and plugins show their correct names but don't show up. When I look into their respective patches the plugin block shows "invalid" at all connection points.
Plugins are all installed and validated at the same location as the previous laptop.
I've scanned all plugins' locations already.
Any advice?
Thank you
Installing usine 5.2.231211 on a new M3 Mac: plugins from previous workspacenot loading "invalid"
unguitar
- senso
you'll have to rescan all your plugins without guaranties, I'm not sure HH5 is compatible with OSX 14.4.
unguitar
ok, are you suggesting me to check with HH6.x?
- senso
yes
unguitar
after scanning all the plugins HH6 is giving me the same "invalid" messages on the same plugins HH5 was showing.
the plugins are correctly installed as they work fine with Reaper and Live.
- rlgsbt
Do your plugin appear in Usine plugin list ?
Have you tried dragging the plugin from the list into your patch?
Or simply put your ultratap back in a rack, since there are no special connections ?
unguitar
@rlgsbt
yes, if I put drag them in the rack from plugins' browser they load just fine, but all settings are lost.
One reason which puts Usine high in the performance oriented audio applications is its smooth and convenient preset management, which allows you storing and recalling the full snapshot of the current audio routing/mixing PLUS plugins' state and presets.
This is a pretty unique function, which is totally absent in Ableton Live, for example.
