Page 1 of 1
Decent laptop ?
Posted: 14 May 2024, 14:59
by daviche
Hello everyone.
Having worked on a Mac for many years (including with Usine), I'm thinking of buying a PC laptop to use exclusively on stage, with Usine.
Can you give me your opinion on a configuration like this?
Asus VivoBook 16X N3604YA-MB014W (16", IPS, Full HD+, 16:10, 60 Hz, Ryzen 7 7730U, RAM 16 Go DDR 4, SSD 1 To, Windows 11)
AMD Ryzen 7 7730U (Octo Core 2 GHz / 4.5 GHz Turbo - 16 Threads - Cache 16 Mo)
CPU frequency 3.2 Ghz, 8 core
AMD Radeon Graphics
Thanks !
Re: Decent laptop ?
Posted: 14 May 2024, 16:11
by rlgsbt
this will be more than enough for all the audio in Usine. The most important thing will probably be the sound card.
Re: Decent laptop ?
Posted: 14 May 2024, 19:14
by oli_lab
I opted for a MINIS FORUM Venus UM790 Pro Mini PC AMD Ryzen 9 7940HS with 32Go RAM
it's not a laptop but even smaller !
added a small keyboard + a 7" beetronic tactile screen !
run very well !
Re: Decent laptop ?
Posted: 21 May 2024, 19:08
by gurulogic
One of the biggest factors for selecting a PC (IMO) is that there is no problematic hardware / driver configuration that will cause a high DPC latency, and therefore poor realtime audio performance. Sometimes this can manifest as a network or bluetooth etc device that can be disabled, sometimes the problem can be deeper rooted and unresolvable.
I do not see the exact model listed here, but when I search this page for "16x" some similar models come up that seem to perform favorably
https://www.notebookcheck.net/DPC-Laten ... 376.0.html
https://www.resplendence.com/latencymon
Between ensuring that your laptop has adequate resources available for good realtime performance and a rock solid audio interface (RME?), as long as you are certain that you have enough system memory, then you should be good to go
Re: Decent laptop ?
Posted: 30 May 2024, 10:33
by senso
yes the MINI FORUMS is great :
https://www.amazon.fr/gp/product/B0CCXN ... =UTF8&th=1
the pro version around 800€
