Bitmap /Video out
Bitmap /Video out
Unread post by 23fx23 » 21 Nov 2023, 10:57
Hey there,
Getting a bit back to my beloved usine after a while, and quite excited, seen it evolved a lot since, and got new stuff to check :)
Something i noticed and had a doubt about:
by default when first re-opening usine, i couldn't use bitmap out, (say a fader bmp out to another bmp in didn't work)
But then i went to global setup options and noticed it worked again if enabling video out.
I don't recall was needed in earlier versions, jut checking if 'normal' or if i missed something ?
Unread post by senso » 21 Nov 2023, 22:03
not normal, it should work without video activated, I'll check that
