Page 1 of 1
Import audio with Markers (BWF)
Posted: 25 Oct 2022, 17:35
by cmodica
It would be useful to be able to import into HH an audio file containing markers in order to be able to use these markers in a sampler.
Example: I put markers at specific moments of an audio file in Reaper. I then export this audio file with the Markers only option in the BWF menu.
When I import this file into an HH sampler, the markers are present.
Re: Import audio with Markers (BWF)
Posted: 26 Oct 2022, 04:22
by Ariajazz
What I do is save a preset file created by a preset manager module associated with the sampler player within the same patch . This preset file contains the markers and any other informamtion contained in the patch. Then I load both the audio file into the sampler and recall or read the saved preset file. I don't think there is such a way to embed markers into audio files, Markers are created by the sampler PLAYER and are just that, markers , they are not any kind of information that can be contained within an audio file, if I'm wrong please correct me.
Posted: 26 Oct 2022, 13:14
by SylvainT
BWF looks to be able to embed markers so maybe Senso would be able to import them. Maybe we could have a look on this.
Posted: 26 Oct 2022, 23:17
by Ariajazz
Forgive my ignorance... What is BWF?
Posted: 27 Oct 2022, 12:22
by cmodica
SylvainT wrote: ↑26 Oct 2022, 13:14
Yes, I think it should be an interesting improvement.
Ariajazz wrote: ↑26 Oct 2022, 23:17
Ignorance is when you don't ask for information about what you don't know yet.
BWF is Broadcast Wave File.
These are metadata that are written with the wav file. This can be timecode, track name, markers, etc.
BWF data are very much used by film sound engineers, but not only. There can be very useful.
https://www.audiorecording.me/what-is-b ... r-daw.html
https://en.wikipedia.org/wiki/Broadcast_Wave_Format
In fench :
https://fr.wikipedia.org/wiki/Broadcast_Wave_Format
Have a nice day and thank you all.
Posted: 27 Oct 2022, 15:22
by Ariajazz
Thanks a lot for the information and link.
Posted: 28 Oct 2022, 23:28
by oli_lab
Hi!
I did that with global arrays, that might help.
It's working but I still didn't figure out where the global arrays files are saved in my computer !
savemarkers.wkp
Posted: 02 Nov 2022, 17:18
by oli_lab
I improved the patch with using some scripting.
Now .mkrs files are save along the wavefiles (makes it easier to retrieved)
enjoy !
save markers by script.pat
Posted: 02 Nov 2022, 17:44
by cmodica
Thank you for your work oli-lab.
I can’t test because i am far away from my studio this week.
But my question was not to export segments from Usine. But to import in an Usine sampler a wav file with markers inside it. Markers are write in the meta data of a BWF in Reapers for exemple, or an other DAW.
Posted: 03 Nov 2022, 11:44
by oli_lab
I know my patch doesn't answer your need, but can offer an alternative before something else comes out !
can you send a file with BWF via wetransfer so I can have look at the chunk inside it and see if it's easy to read the BWF infos ??
Posted: 04 Nov 2022, 10:14
by cmodica
Thank you Olivar.
I will send you a bwf file as soon as i will come back to my studio, next week.
Thank you very much.
Posted: 04 Nov 2022, 12:30
by oli_lab
I had a look in the SDK and nothing can read the BWF data so far.
I made a BWF file with reaper and trying to localize the chunk.
so far I managed to pin point the list of markers at the end, as well as their position in samples.
Need to get some other datas as the total number of samples and I should be up and running.
Mind you it's a side project, so be patient !
Posted: 05 Nov 2022, 22:43
by oli_lab
It was raining so, I did some coding :
will be in the addon soon
not finished yet but here for you to test it.
only the markers array output is working
I'm planning to get the name of the markers, that could be handy to select markers by name
the metada output would be to read comments from the BEXT chunk (comments, originator, loudness, etc... Maybe too much work but could be interesting
tell me !
Posted: 07 Nov 2022, 10:47
by cmodica
Thank you very much Olivar.
But i can't test your patch because i am on Mac OSX. The file "Oli_Lab_BWFdata.usr-OSX64" is not in the zip package.
Posted: 07 Nov 2022, 11:44
by oli_lab
Argh !
sorry for that,
I'll fire up the Mac mini asap
Do you use Wav or Aiff ?
so far the module only works for Wav with BWF data in it
it is differently organised chunkwise form wav to aiff and I need to make a different logarithm.
Posted: 07 Nov 2022, 13:04
by cmodica
I use Wav.
thank you, very much.
Posted: 07 Nov 2022, 15:57
by oli_lab
Ok,
it will be wave only then
I managed to get the name of the markers, if any.
the Bext chunk is not very useful, I'll skip it for now.
MAC Os version will be ready as soon as I managed to update the Mac Mini
Posted: 09 Nov 2022, 23:13
by oli_lab
the BWFdata module is in the oli_lab_pack module
You need to remove the old one before downloading it
there's a demo in the examples folder.
Posted: 14 Nov 2022, 12:33
by cmodica
Thank you, it works.
You are a master! Thank you so much.
This pack is a fantastic resource for HH.
Posted: 06 Dec 2022, 00:12
by oli_lab
the BWFdata module has been updated and now it works better !
just need to update the oli_labàpack add on.
Posted: 03 Mar 2023, 18:45
by oli_lab
as of march the 2nd, the BWF module as been fixed, no more problem when the file has no BWF data.
please update the oli_lab_pack addon !
