Page 1 of 1
HH5 v5.2.220218 does not mantain VST GUI position
Posted: 24 Feb 2022, 22:11
by Ariajazz
Hello All. Previous version did it. Usine was able to keep the selected position of VSTs. Now when you open them they do it at a specific XY cordinates of the screen and not at the selected position. For me this is kind of an issue because with previous versions of HH I could open several VST GUIs each opening at its desired selected position, this way I could have several VS GUIs open in a organized way on the screen. Any way to tweek Usine and solve this?
Re: HH5 v5.2.220218 does not mantain VST GUI position
Posted: 16 Mar 2022, 21:57
by Ariajazz
No one?
Posted: 17 Mar 2022, 07:34
by senso
looks more as a bug report ?
We'll check
Posted: 22 Mar 2022, 20:45
by Ariajazz
Any improvement on this?
Posted: 24 Mar 2022, 08:48
by senso
not realy.
You can try the following tweak:
replace the file /resources/devices/PluginWrapper.usr-win64 by the attached file?
Posted: 25 Mar 2022, 21:37
by Ariajazz
Thanks Senso. So far the tweak seem to be working.
