different folders for plugin presets
blugaruda
Hi, I'm evaluating Zynaptic's excellent Morph 2 plugin at the moment but HH4 is not remembering my presets. It turns out that the factory presets are stored in one folder and user presets in another. For some reason HH4 can't see my user presets. I've tried it on Logic Pro and it's not an issue there so I guess it's some setting in HH4. Can anyone tell me what to do about this? Thanks.
- rlgsbt
Hi Blugaruda,
Welcome in Usine.
If you want Usine to record/remember your preset with a VST, you have to create an Array from the VST's parameters, a "pass if change" and then write a new preset in Usine (not with the VST)
Welcome in Usine.
