webcam behavior
seamus
webcam behavior
Unread post by seamus » 07 Jul 2020, 03:31
Hi
i have been trying to trouble shoot my problems with my webcam on my laptop running windows 10. It seems that another app has a driver that fights with the webcam driver for use of the webcam and i constantly have problems. I think it might be possible that Usine is causing the problem but maybe im wrong. I know that Hollyhock has some features that use the webcam. If you know any solutions to this problem i would appreciate it. Im just trying to use the webcam for normal video application like skype but the webcam seems to have drivers that fight for use of it. I dont know the name of the driver that Usine might have installed somewhere and if i can disable it.
thanks
seamus
Unread post by seamus » 10 Jul 2020, 02:38
i have never wanted to use usine for any video applications. I have all video features turned off in usine preferences. I notice that when i first open Usine the webcam is turned on and taken over for a moment even though it is turned off in the preferences. So there is some process using access to the webcam.
i still think maybe this process is fighting for control when im using zoom or skype.
Unread post by senso » 11 Jul 2020, 14:35
hi seamus,
Normally Usine shouldn't hook the webcam if all video settings are off (cameras and video engine)
Try also to remove all video-IN devices in the devices-panel (or clear all devices)
seamus
Unread post by seamus » 22 Jul 2020, 00:09
that helped thanks Senso! i dont have this problem anymore!
