Implementation of scenes
joojoo1234
Unread post by joojoo1234 » 27 Nov 2007, 21:00
In what I am doing - don't need the scenes - do you use them to help setup - are there any benefits derived from using scenes as opposed to just loading up the file- I guess if I am accompanying a live musician it would help to have one scene rather than just hit on instead of off...
Unread post by bsork » 27 Nov 2007, 21:33
I guess you're referring to the scenes or snapshots in the conductor..?
There's definitely a benefit in using scenes if you're either moving between different parts/setups within a song, or if you're using the same workspace for more songs. A click or two let you create or recall a "preset" of the whole workspace.
Remember that you can also have a fade time for the scenes.
Users browsing this forum: No registered users and 584 guests
