preset manager HH4
Posted: 30 Dec 2019, 06:56
I'm having trouble with the preset manager. Mostly with the workspace version of it:
If I change between workspace presets, some things change but others don't:
1) the button statuses (the MIDI/muted buttons and the main reverb buttons) do not save. They are marked "save in preset".
2) the send knobs do change
3) the patch presets change, but the names in the drop down do not (very frustrating)
All of the buttons are in the patch. The "Twin Verb Router" is a sub-patch so I can reuse it easier. The above behavior is confirmed in the other, similar racks. I also made sure that the button statuses would save within the presets and they do, but when the workspace changes the presets: no change in those buttons. This really needs some more work IMO.
I had a very similar setup in HH2 and it worked really well. The workspace preset was of course much bigger and over in the left.
Any pointers?
-John
Any pointers?
-John
