Posted: 22 Nov 2007, 19:35
1. If you install a new version or copy in Usine. And pull the workspace from one to another new version or not. Does it put the patches in the new version or copy of the same version or is it pulling these patches from the old folder.
2. I had an occasion where it brought up in Absynth the wrong patch... what does usine do with absynth does it bring up patches or banks - what is the best way to organize this for smooth operation and minimum cpu - do extra patches your not using use the cpu much? I have store the absynth pane (as normal) and then I have a save function on top by the windows top bar? Whats the difference (does usine want one or the other?)
3. I am getting ocassional stops - or sometimes - due to cpu use. I have cloned and not copied. Do user curves use cpu - are they costly? Should I eliminate break points?
4. I am dismayed by the way Usine brinks up my workspace. Is it the workspace I just left or did I contaminate the fresh patch or is this to my benefit. I want the program to load a blank and then I manually choose my workspace.
5. I wish usine had an automatic program just like creative that would say speaker left front speaker left back... so I could hook up cables without second guessing and such. I guess I will make that myself.
6. It seems like patches move around in the sequencer window... I am speaking of their endings. Does Usine sometimes grade on a curve so to speak and place them slightly different? Can I snap them in the window?
I will read the manual again but could you one by one answer these as breifly so as not to take to much of your time. That time when it loaded the wrong absynth patch after over and over again doing it right was bizarre. Does the patch need to be in one specific place. Give me some tips on cpu usage.
Thanks. This program makes electronic music interesting to me when in general it doesn't.
