Page 1 of 1
Posted: 19 Mar 2019, 10:30
by Garyool
Hi
I have a problem with video player, the player plays my video faster than the normal speed and i didn't touch the speed bouton.
The video format is .mp4 or .mov and it's the same result.
Does anyone have an idea ?
thanks
Posted: 19 Mar 2019, 14:11
by x.iso
maybe sample rate of included audio doesn't match audio engine setting?
Posted: 19 Mar 2019, 16:12
by cmodica
I had the same problem a few months ago. I didn't solve it but i should worked. So i synchronize Hollyhock and Cubase. Compose the sound with HH and Cubase and read the video with the Cubase video player.
There wasn't any sound in the video that i try to play with HH. It was a H264 .mov video.
I am interesting if you find the reason why it plays faster.
Posted: 19 Mar 2019, 16:23
by grego mondo
frame rate video (in setup/video) ?
Posted: 19 Mar 2019, 19:08
by Garyool
My Fps = 24
I try with one of provided video like "forest", i have the same problem ...
i haven't audio on my video
Posted: 21 Mar 2019, 08:08
by senso
humm, It should not.
Or maybe only few frames faster.
For a test, open the same video in vlc et usine and try to start them at the same time (almost).
ps:you can also adjust the video speed on the player itself it can help.
Posted: 28 Mar 2019, 11:37
by cmodica
i have a problem with the video player. The FPS is not stable ? there is some variation between 22 and 25 FPS. I play the video on a 2nd screen thru a video projector.
I don't have any external clock or SMPTE generator. Only my laptop MacBook Pro retina, Mac OS 10.12
Posted: 28 Mar 2019, 15:46
by senso
try to set the audio engine speed to the fastest as you can in the setup.
for example 200fps.
this will improve the global video engine speed and so the precision.
your 25fps videos will stay at 25fst, but the engine will respond faster.
Posted: 28 Mar 2019, 17:55
by cmodica
Ok
Thank you very much.
Posted: 28 Mar 2019, 18:00
by cmodica
Ok. Thank you. It works !!!
Posted: 28 Mar 2019, 18:17
by senso
Be careful, it increases the CPU load...
Posted: 28 Mar 2019, 20:14
by x.iso
If I'm not mistaken, videos are decoded in same way they will with any video player by default, meaning if dGPU decoding is enabled for certain codecs, it should also offload to dGPU in Usine?
Posted: 28 Mar 2019, 20:30
by senso
yes we use the ffmpeg library to decode videos. This library uses GPU if needed independently the settings of Usine.
Posted: 08 Apr 2019, 15:36
by Chafff
Hello I have the same trouble here
my video is played 2time faster than the orginial one, I've tried to setup the audio engine at 300 but nothing happend.
when I play the Usine demo video they seems ok for the speed but it lagg.
thank you for your answer
Posted: 09 Apr 2019, 09:20
by senso
I think that it comes from the codec of the video. Can you try to convert it into another format ?
Posted: 12 Apr 2019, 10:13
by Chafff
I convert it in AVI uncomressed the speed seems ok but it lag a bit (even though my footage is in 720/480)
I'm running on a windows 10 familly 16G ram I7-4720HQ Nvidia Geforce GTX960
I've tryed with the demo video file and it still lag a bit
Posted: 16 Apr 2019, 21:44
by senso
The video engine totally rewritten in the next major release. Much more powerful and efficient.
Posted: 17 Apr 2019, 11:47
by Chafff
Great :)
by major release you mean HH4 or 3.x ?
Posted: 17 Apr 2019, 21:57
by senso
HH4
