Posted: 27 Oct 2017, 18:54
I find this error when i load presets to my patch.
Do you what can i do ?
Thanks.
Thanks.
Thank you.senso wrote:It's a bug, solved in the 3.0.145
actually, this command doesn't work on an empty preset panel. Just create at least one preset, then you'll be able to load a file.
or wait few days until the new release.
