Page 1 of 1
Posted: 16 Aug 2017, 00:12
by Ariajazz
Hi. That is...
Is there any list of DMX interfaces of supported by Hollyhock 3? Help files and manual only reffers to ENTEC. Is any other USB to DMX supported?
Posted: 18 Aug 2017, 19:27
by nay-seven
Most of recent interfaces are supported cause they use the same DMX protocole,
Now we can't provide a list cause we'll need to buy and test a huge amount of interfaces !
Posted: 11 Dec 2017, 16:44
by pierrick.lerille
Hi Nay,
Dow you now if Sunlite interface does work with Usine 3 ?
Thank you,
Pierrick
Posted: 11 Dec 2017, 16:48
by nay-seven
Sadly i don't know this interface , sorry
Maybe someone else here ?
Posted: 13 Jan 2018, 08:25
by imodularsynth
Hi all,
I can also recommend the KissBox DMX interface, which uses ArtNet standard protocol and is therefore directly compatible with Usine (this is the interface I use in my setup)
Benoit
Posted: 13 Jan 2018, 22:57
by oli_lab
I use dmx king products.
Artnet to dmx.
Strait forward
