Another future request and can be a bug ?
franck
Unread post by franck » 26 Sep 2007, 14:26
Helllo Olivier an Usiners,
a suggestion: A mute and solo button on the master section (each output could have its mute an solo button), il well be very fine.
A bug ?
The sequencer midi file player (in template, sequencer files) has not possibility to switch between differents midi files in the menu, buttons 1 to 8 are innactifs. Is it a bug or different mode operation than Piano roll module.
Franck
Unread post by senso » 26 Sep 2007, 14:34
thanks for feedbacks
franck wrote:a suggestion: A mute and solo button on the master section (each output could have its mute an solo button), il well be very fine.
Actually there is no room on the master section to create mute/solo btn.
But it can easily created in the insert parch?
A bug ?
It's not a bug, in the seq-midi module only one midi file is available; maybe not so clear.
I'll take a look
franck
Unread post by franck » 26 Sep 2007, 14:55
Hello Olivier,
I know it is possible to create a patch for "muting" an "soloing" each master out but i could be more esay and mode visual if each output has its buttons (with the top or with the lower part of vu meters).
I think it was so clear if it is the same midi sequencer in the 2 versions.
Franck
