Page 1 of 1
Posted: 05 Apr 2017, 19:05
by 23fx23
It seems they moved recently a bit from their closed ios only system to editable software, midi and sdk,
was wondering if we could use osc/midi or something from usine to control lights, create custom 'modes' ect on the device with usine,
any user tried that or feel to share experience with such device?
edit: looked a bith further at their sdk i feel it seem doable to code a usine module for that unless i miss something
Posted: 13 Apr 2017, 13:29
by r.erorr
How can you use it with Usine?
Posted: 13 Apr 2017, 13:57
by 23fx23
well i didn't test yet with usine but i think with coding a user module that include their sdk library, man could for exemple access its multitouch data out as pins, or have inputs like a matrix / array input to control the leds. or the base module could out of the box have 'modes' templates ie faders banks/matrix/scales/sequencers ect we could dynamically switch/change customize, then it would be easy to remote a vst, usine item, send midi or OSC , use preset managers, automation record/play ect.. Actually it can be used with midi out in but that makes things bit more complex to filter/tweak
