Hello & a question
kara
Unread post by kara » 07 Sep 2007, 15:15
Hello from a new member who is planning to buy Usine :)
Since I'm playing a Midi guitar I have a question
The problem with a midi guitar is that it doesn't send midi notes off , only midi on.
So in principle I would need a litle module that send a MIDI NOTE OFF message before sending the actual MIDI NOTE ON message. Is this possible in Usine ?
If this is possible I could insert this module on my 6 midi channels (each string sends on his proper midi channel) and my problem would be solved.
tia
k
Unread post by senso » 07 Sep 2007, 21:53
Your problem can be solved very easily with Usine.
on a patch put the following modules:
- input output / Midi input (unpack option activated)
- input output / Midi output
- midi / Midi filter
- midi / create Midi message
- math / Variable
- Event Control/ Wait 1
1) connect [Midi Input](midi) ---> (in)[Midi Filter] to let pass only note ON msg
2) [Midi Filter](code1) ---> (in)[Variable]
3) [Midi Filter](send) --->(in)[Wait 1]
4) [Wait 1](out) ---> (affect)[Variable]
5) [Variable](out) ---> (code1)[Create Midi] and set the (msg) to "NOTE OFF"
6) [Midi Filter](send) ---> (create)[Create Midi]
7) [Midi Filter](out) ---> (midi)[Midi Out]
8) [Create Midi](out) ---> (midi)[Midi Out]
save this patch as "filter one channel.pat"
now take a blank patch and add 6 "filter one channel" as sub patch (with Ctrl pressed in the browser)
In each sub patches change the 'channel filter' of the [midi filter] to filter respectively channel 1, 2, ...6.
Thats all...
Take a little time to understand how it works. Usine is rarely more complex than this example.
Hope it will help
kara
Unread post by kara » 08 Sep 2007, 21:00
Thanks for your answer Senso, I will try this
cool,
k
Users browsing this forum: Google [Bot] and 13 guests
