Is it possible to simply remplace VST by Au without lost all your saved parameters (routed button, preset etc...)?
I've got some VST GRM tools in my session and since several day, I've got this message:
"Authorization Stf Exception
GRM Tools Classic cannot run, because an error occurred.
Invalid method name: "sendEncryptedCommand"
I've reinstalled my GRM and now only AU is working on Usine, not the VST...
Strange no?
Thanks.
Remplace VST to AU
- senso
hello,
It's not an error message from Usine. Please try to contact the GRM support? it seems related to authorization key.
Unfortunately you can't exchange VST and AU without loosing presets. It seems normal because it's absolutely not the same types of preset formats.
