Is there any way to get the sound from a browser into Usine (set as ASIO) without external cables ?.
It would need some type of virtual audio routing that a browser sound can be sent into,
and whose output looks like an ASIO input that Usine can detect.
I'd like to mix youtube audio with VSTi outputs so I can practise by playing along to youtube videos.
I could mix the sound externally, but if it can all be plumbed internally that would be useful.
Simon.
youtube sound into Usine ASIO
drakh
depends on your soundcard if it supports internal signal loopback
