Few troubles with the grid. Bugs ?
La Tenaille
Unread post by La Tenaille » 10 Dec 2015, 19:32
- When I copy/paste a grid item, the pasted one are a little shifted : overlapping the previous section and stopping before the end of the section.
- It's tricky for me to drag a point to 0 (bottom) inside an item : If I don't go very slowly, the point stop before 0.
- When inserting a new section between two existing ones, some items are not moving correctly to their section.
Do you experiment the same troubles ?
Shintylla
Unread post by Shintylla » 19 Dec 2015, 10:09
grid has many little troubles..
