Preset and Device not saved on each workspace.
Jules.W
Unread post by Jules.W » 12 Oct 2015, 16:56
I work on several workspace at the same time for different music projects.
And I observe that each time I'm switch the workspaces, the device panel setup are the same...
for exemple, I've got three device input audio for the project1 (Input 1,2,3).
I've got two other for the project 2 (Input 5,6).
When I work on the project 2, I delete the device input 1,2,3 to conserve the two other I want (Input 5,6).
And when I re-opened the project 1, Input 1,2,5 are red, and they disappeared from the device panel...
It happened the same for setup configuration (Record folder for exemple...)
Did I miss something?
Thanks.
Jules.
sephult
Unread post by sephult » 12 Oct 2015, 17:02
The devices I believe are setup in the config file and the same for each workspace. If you delete from the config, it will show as missing and turn red.
Also the devices are located in the /config/devices folder.
-s
La Tenaille
Unread post by La Tenaille » 12 Oct 2015, 20:31
I've one Usine per project as a workaround, and it works fine.
You can also load/save your device set and reload your workspace.
Users browsing this forum: No registered users and 352 guests
