Usine and Kinect
I haven't use my kenect for a while, but as far as I can remember, you need a middleware, then something like Processing to plug into the middleware and send OSC to Usine.
not as straight forward as with the Leap Motion...
https://en.wikipedia.org/wiki/OpenNI
yes, there's several applications you can use
here a MAX one with autocalibration that send OSC
http://jpbellona.com/kinect/
i use Nimate (not a freeware) , very usefull , in osc and midi
L'orchestronique - foSolo
http://www.arbre-canapas.com/l-orchestr ... ideos.html
there is also OSCeleton:
https://github.com/Sensebloom/OSCeleton
CleverConQueso
Same as Oli - It's been several years since I did it but the trick at the time was a hacked driver and Processing middleware to convert the Kinekt to OSC. Since then, I believe a proper driver and API for Kinekt have been released.
At the time, it was necessary to 'register' a body with the Kinekt. I think that has changed since, but it was a PITA.
On the more esoteric side, I found the literal interpretation that Kinekt offered to be actually less useful musically than the native webcam support in Usine. For an interactive art piece, I didn't need to know distance and joints as much as just areas of the screen and level of energy. Here's a video from that project - https://www.youtube.com/watch?v=-WqBuaQakgI
I'm actually back at it now working on another interactive sculpture and trying to figure out if more than one LeapMotion can be supported at once.
What I probably do is use a Linux computer fitted with the kinect sending osc to Usine thru ethernet
That will be one computer as a powerful 3d sensor and amother one dedicated to sound
What I like with kinect is the ability to measure distance at witch the subject stands, very useful in multiple loudspeaker configuration
http://doc.ubuntu-fr.org/kinect_openni
Users browsing this forum: No registered users and 248 guests
