Page 1 of 1
Posted: 17 Jul 2007, 23:11
by felix509
Hi there, Is there a way to do have different devices as the inputs and outputs???
I want to use the ASIO4All output from WinAmp as a stereo input, process with VST effects, then output to my EchoAudio Layla3G analog outputs..
So far I can only choose one or the other, and that will not work for my apps..
Lars
Posted: 17 Jul 2007, 23:52
by lung
There's a program that you can choose to install with the trial version of Reaper, called ReaRoute which can route audio between ASIO apps, but it may only works between App1 & Reaper. Slight chance you can route audio from App1 to App2 (where App1 & App2 are not Reaper), but I have a feeling it won't. I'm not at my DAW atm, otherwise I'd try for you.. let us know! :)
Posted: 18 Jul 2007, 00:02
by lung
Maybe this may help..
There are a few very cool MP3 playing VST plugins you could use:
xtal
mp3play
Or a more complex solution may be:
..there are a number of VST plugins that can route audio from one VST plugin to another..
Winamp has a VST plugin addon here.
Might be possible to use that with a VST audio i/o plugin like getout or one of the other ones .. can't remember the names of the rest ATM..
Then just use the regular ASIO plugin out ot the Layla3G.
Posted: 18 Jul 2007, 00:07
by felix509
Thanks for the help, i will try the various suggestions..
I have tried a few different VST hosts, but they all will only use the same device for in and out..
FYI, this is what i am trying to do..
http://www.mp3car.com/wiki/index.php/AS ... ing_Method
Xover, EQ, and delay for each channel..
So i am looking to take in my WInamp output(ASIO or kernel stream), use the VST host to do my processing, thn out to seperate amps via the Echo Layla..
I may have ot pick a different card, i will see..
Posted: 18 Jul 2007, 09:30
by senso
With some audio cards (like RME) you can run several applications at the same time and easily create intern routing to communicate between them.
I do it often.
