Thank you Oli_Lab!
sephult
Unread post by sephult » 10 Jun 2015, 06:50
Hi Oli,
I wanted to thank you for the gain and clipper modules,
I actually had been building a saturator for awhile, and ended up adding these on in addition for my own personal Add-On...... hopefully to come out soon.
They are great, I just wanted to give you thanks and much appreciation for your effort...
I am hoping to be able to put these to good use. Great work!
-S
Unread post by oli_lab » 10 Jun 2015, 18:33
:) thanx !
new version of those modules are on the way with smooth volume control.
on github : :https://github.com/Oli-Lab/hollyhock-gr ... master/src
no OSX yet
sephult
Unread post by sephult » 10 Jun 2015, 21:46
I even built a custom background with a dedicated section for your modules :)
I am a huge fan of iZotope Trash 2, I love the starved input fading grainy noise type distortion. The clipper I have been working I can sometimes dial something similar in, but mixing between my modules and yours I get a ton more tonal variants than I had before. I will keep my eye out, again thanks. Hopefully start diggin in the SDK stuff sometime here slowly.
-S
ceasless
Unread post by ceasless » 14 Jun 2015, 12:02
OS X versions now available! https://github.com/ab5tract/hollyhock-g ... r/bin/os-x
You will need to click on the module's link, and then download via 'save as' via the "Raw" link.
Or wait for oli_lab to update his add-ons.
Oh, and I very much agree, oli_lab is awesome :)
Users browsing this forum: No registered users and 349 guests
