Page 1 of 1
Posted: 28 Apr 2006, 21:08
by laserbeak43
hi
how do i sync this to the actual tempo and not just the start and stop? if i change the tempo on the fly while playing the step module still plays the same.
also how do i see the actual values of the steps that i'm changing?
while im editing steps i dont see the values and it is mighty hard to make them precise while playing.
btw i'm tryig to use the step sequencer to push the sampler by the pos input i have the len input of the sequencer pinned to the len output of the sampler so the sequencer is the length of the sample
Posted: 01 May 2006, 19:21
by senso
In the Step module you can change the Sync parameter to adjust the speed to the synchro.
In Sync=bar the step module adapt his speed to the tempo.
See the documentation about this point.
I know that the step is not precise enough, for example to adjust midi notes of a sequencer.
I shoud improve this module?
Or, perhaps there are VST MIDI step sequencers more efficients for free?
If you find one tell me.
Posted: 01 May 2006, 19:23
by laserbeak43
i'll look around.
Posted: 01 May 2006, 19:28
by laserbeak43
just tried stepchild and stepmachin but they dont seem to work.lemme try to make somethin in SE
Posted: 01 May 2006, 20:04
by laserbeak43
unfortunely there's no input for tempo in synthedits bpm module and it syncs to host tempo. so i wouldnt be able to use the sync module. if you want to see what im doing in synthedit just let me know
Posted: 02 May 2006, 17:57
by senso
I discover a synchronization bug in Usine.
In the next release (perhaps the 1.013 next friday) you will be able to use:
-Tobybear Stepper in the "midibag"
-The Stepchid
as step sequencer.
Posted: 02 May 2006, 18:04
by laserbeak43
YEAH BABY!
