Load patches and IB Behavior
I´m working with USINE Stage v5.80 and I'm configuring my setup in the way that I load different patches for each song, this is: I select songs and load them with their respective patches. I also design different configurations in the Interface Builder (IB) so I can have a nice customized view of the settings for each song during live performance. The problem is that every time I load a song USINE Stage changes to the GRID view and it does not remains in the IB view (USINE Pro v5.20 did not use to do that). Is there any way to accomplish this and make USINE Stage stay in IB view when loading songs and their patches?
you can create a patch and use a dashboard module to force IB mode..?
Thanks for repplying but I have no idea how to do that. BTW does Usine Stage v5.80 have better audio engine than previous versions?
something like this
and each new version gives improvements yes
Thank you very much for helping out. I'm really satisfied with Sensomusic software, it is the only tool I've found that can achieve the requierements of my spectations, even when I'm aware that I only know a negligible part of its power and features I trully believe on its huge potential. I wish I could have a way to learn more about and how to use the software in depth. I want to be grateful for all the help I've received in the forum, specially from you Nay-Seven. Thus I'd like to compensate and give back all the help received but not sure how. I've been beta tester for JamOrigin MigiGuitar, Admiral Quality for PolyAna and some other free plugin and software developers. Perhaps I can contribute in the progress and development of Sensomusic software by translating into Spanish user's manual and any other writen material or maybe by testing features of the software or helping with the marketing and promotion of you product which I have done already with your software through my internet resources and personal recommendations to other collegues (I'm a sound Engineer and guiatrist) and students. I do clinics and courses about audio and uses of software such as Sonar, Pro Tools, Cubase, Waves Plugins, and some others. In conclusion, I´m totally willing on give any help you may need in the developement of this great software.
BTW the dashboard tool you suggested is only available in the Pro version not in the Stage version. Any other solution?
Thanks for the proposition ariajazz,
About the Spanish translation it's really a huge work, especially if you don't use Hollyhock, next version will have more than 90 pages and the main problem is the maintenance, cause i made changes regularly and all manuals must be identical.
so maybe the better way is to promote Usine around you?
For IB mode, create a midi learn on the IB button and create this patch ( respect your CC number, of course..)
I'm a professional translator. I use to do translations for Microsoft SPAIN stuff, we can work on that. I've been tempt in start using HOLLYHOCK free lately but there's no way to download it from your site, i get constantly an "unknown net error" message. I've try different computers and different location and is the same, download stops after 2 or 3 minutes.
I understand that I should locate these modules on every patch I intend to to be loaded in IB view. They are in differen tracks most of the times.
Thank You.
Thank You.
ok, i will contact you when the new manual will be ready...
about the IB mode, no, only one by workspace will work
OK let me know when it is ready. And yes I already teste and only one is need it
Users browsing this forum: Google [Bot] and 14 guests
