sample loop
Have you set the grid line to 16 bars too..?
if the problem is not here, can you export a simple workspace to illustrate the issue...?
Nay 7
yes I set the grid line to 16 bars.
I joined the example with uploader.
try to play the song several time, the sample does not play until its end.
thanks a lot to look at the pb.
Thanks, but you need to use the export feature in the contextual menu, cause the workspace you send don't contain any sample, so i can't test..
when you export, Usine create a folder named audio which contains the samples
ok, sorry.
I just sent you the export. (.rar)
all the best
all the best
ok, there's some conflict between synchro mode in this particular case, will be solved on next version.
Waiting for this, here a workaround:
-set the play loop switch OFF
-set the on activation option to play once
nay 7
thank you.
it works.
and I wait for the new issue.
thank you.
it works.
Users browsing this forum: No registered users and 651 guests
