Page 1 of 1
Posted: 16 Mar 2014, 12:11
by Dr Vrob
I have problems with loops in the samplers.
I use the grid with samplers patches inside
I programmed a 16 bars loop on the sampler
but the first loop is always shorter than 16 bars.
could you help me
all the best
:rolleyes:
Posted: 17 Mar 2014, 08:58
by nay-seven
Have you set the grid line to 16 bars too..?
if the problem is not here, can you export a simple workspace to illustrate the issue...?
Posted: 17 Mar 2014, 22:48
by Dr Vrob
Nay 7
yes I set the grid line to 16 bars.
I joined the example with uploader.
try to play the song several time, the sample does not play until its end.
thanks a lot to look at the pb.
Posted: 18 Mar 2014, 00:03
by nay-seven
Thanks, but you need to use the export feature in the contextual menu, cause the workspace you send don't contain any sample, so i can't test..
when you export, Usine create a folder named audio which contains the samples
Posted: 19 Mar 2014, 00:16
by Dr Vrob
ok, sorry.
I just sent you the export. (.rar)
all the best
Posted: 19 Mar 2014, 22:49
by nay-seven
ok, there's some conflict between synchro mode in this particular case, will be solved on next version.
Waiting for this, here a workaround:
-set the play loop switch OFF
-set the on activation option to play once
Posted: 27 Mar 2014, 09:17
by Dr Vrob
nay 7
thank you.
it works.
and I wait for the new issue.
