Page 1 of 1
Posted: 27 Nov 2013, 15:54
by sephult
Seems I am having issues getting Focusrite Scarlett and HollyHock to play well with anything besides 44k. Everytime I adjust the sample rate I get a "Can't create i/o buffers" and it just goes back to 44k. Forcing from Scarlett will not do anything either because HollyHock has control. Anyone experience similar issues, or have any advice?
Posted: 27 Nov 2013, 16:41
by iococoi
really hard to say..did you try the asio4all drivers?..are you on win? you might want to have a look at the windows sound settings..playback device -> properties->advanced->default format.. windows might be "forcing" those 44.1
Posted: 27 Nov 2013, 17:27
by sephult
Strange thing is without HollyHock open I am able to regain Scarlett control and modify the samplerate. Seems HollyHock keeps forcing it to 44k. Typically I have used no audio on this setup and doing control. Working on network setup now which is proving successful, however I would love to run the setup at minimum of 48K. My Master setup typically defaults to 48K min which I would hate to have to keep changing up the rates depending on application.
Even with windows defaults turned off on the scarlett this still happens
