random conductor
barabou
Unread post by barabou » 07 Jul 2012, 15:35
Hello Usiners.
I am an eternal newbie in Usine. I was trying to set up a modified version of the conductor using fader switch (to make a kind of live like launch clip feature):
position 1) : normal conductor
position 2) : conductor automatically follow the cycle position and switch to the next line at the end of each bar
position 3): conductor switch to a random line at the end of the bar.
it s mostly done.. but I just get some randomization issues. if one can help or suggest something better
you can find the patch here:
random conductor patch
Unread post by nay-seven » 07 Jul 2012, 20:43
i don't have recreate the all patch, cause not always easy to follow the logic of someone else quickly , but if you want experience with a different way, maybe the selector module can be a start :
Users browsing this forum: No registered users and 159 guests
