Posted: 20 Mar 2012, 08:33
Im a BOOTCAMP mac user recently setting up Windows 7.
What is the best way to store and organize Vst presets?
Some folder hierarchy tips would help.
At this point I find myself with:
C:Program Files(x86)/ Steinberg/VSTplugins
Sylenth installed itself there.
The folder has banks of presets as well as a manual and the Sylenth.dll file.
Everything in one place.
On the MAC i was used to seperating the vst's and AU's from the preset folders. Often in some other place.
Does it matter?
I also perhaps foolishly made a couple.
C: Program files/vstplugins
that folder has a bunch of 32bit .dll's and a couple of folders of presets.
alot of others went into the Documents folder.
Seems that documents folder is a good place to keep them.
Then just the .dll 's in the vst folder.
thanks for your organization help.
Does it matter?
