fader value matching a vst value
seamus
Unread post by seamus » 16 Mar 2012, 02:12
I want my usine fader to match the values in my vst.
The vst values go from -24 to +24 (it is for a range of intervals)
My usine fader goes from 0 -1
Im guessing I need some kind of math function to apply to it?
how do i patch it?
would it go between the fader and the vst input?
Unread post by nay-seven » 16 Mar 2012, 08:21
you can set your knob min and max as -24 to 24, then you insert a patch you'll find in modules/data/data manipulation/ change scale (out 0..1) and set it too with min in/max in -24 to 24 like this :
note: this kind of question are more for the patching forum, will move it later.
seamus
Unread post by seamus » 16 Mar 2012, 11:50
Brilliant thank you. Next time in patching forum. Sorry!
Users browsing this forum: No registered users and 1026 guests
