Using customized bitmaps for GUI?
UsineHeaven
yes, all background and Interface design modules can have their own bitmap.
here a personal example :
when you export as VST, the only thing you can't skin is the Usine header like in homing pad VST ( the panic button, sync isolate, cpu and memory vu-meter..)
It's something like Reaktor ensemble if you use it..
UsineHeaven
Fantastic man! Thanks for clarification.
Is there a tutorial that I can follow about using Bitmaps to build GUI?
Cheers,
Cheers,
Hi ,may be this one
http://www.sensomusic.org/wiki/doku.php ... te_bitmaps
Friedrich Nietzsche
Friedrich Nietzsche
it's not really GUI tuto but more for bitmaps manipulations in real time.waolelaid wrote:Hi ,may be this one
Thanks for the link.
So is this the way to create a moving fader or a turning knob?
This is what I am trying to achieve - custom controls, but I am not sure how the images have to be assembled to display the motion.
Cheers.
Cheers.
This is all very helpful.
I will take some time to explore and experiment.
Thanks a lot.
Cheers.
Thanks a lot.
Cheers.
Hi and sorry i didn't understand the question
good evening
good evening
Friedrich Nietzsche
Friedrich Nietzsche
Users browsing this forum: No registered users and 343 guests
