Anyone got this working with Usine to run VST plugins etc? It uses osc and I've managed to get it working with Reaktor but not sure how to set it up for Usine
http://konkreetlabs.com/
Konkreet performer
Here what i understand from the konkreet web page:
In Konkreet Performer configuration page, make sure the output I.P address points to the computer that runs
Usine.
Make Port No. the same as "Local Port" in Usine (8000 by defaut)
activate OSC and trace in in Usine OSC setup( [ CTRL+F10]
now check if you see something in the console view
Usine.
multiphone
Don't forget to make "ad hoc" wifi network between your computer and your IPAD.
And this work like a charm with Usine.
Best
Best
Users browsing this forum: No registered users and 216 guests
