we are a team
we'd need to share our patches & our worspaces
how could we do that, considering:
- we use specific design preset for UI elements,
- we use compiled user module (we already made some test... guys, again, you rock!)
should we share the workspace + the patch + ALL specific stuff ?
how could we do this easily ?
best,
share a workspaces & patches + specific design easily ...?
julien
julienbayle.net
designthmedia.com
soundcloud.com/protofuse
_ _ _ _ _ _ _ _ _ _ _ _ _
Ableton Certified Trainer
julienbayle.net
designthmedia.com
have you test the menu file/export workspace function..?
[ ctrl+E ]
[ ctrl+E ]
yep
but it exports the workspace & the patch.
if I use specific module preset & specific bitmap for knobs (for instance), how would it work ?
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
yes, this can be improved .
waiting for this you can put your users module in your personal library and share it
about the design, you can create a dir in files/skin/my skin and share it too ..?
it was just to understand how it works.
got it!!
thanks.
I'll do that and it is very ok
got it!!
thanks.
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
Users browsing this forum: Google [Bot] and 404 guests
