Hi there,
I'd love to design some leds.
Should I use the sdk ?
Is there another way?
I could use knob without nothing as output and only a trigger in input as a trick/workaround, but in order to light the patch a bit (I mean optimize it a bit) maybe there is another way.
best,
LED module redesign, sdk only?
julien
julienbayle.net
designthmedia.com
soundcloud.com/protofuse
_ _ _ _ _ _ _ _ _ _ _ _ _
Ableton Certified Trainer
julienbayle.net
designthmedia.com
you can use any pictures made with gimp or photoshop or whatever
here an ugly example for a black background :
then edit the layout of your led module and use this picture as background
*set frame count to 2
*set it to vertical
* click on fit size
*set it to vertical
* click on fit size
Yan, sorry.
vraiment
ma question sent le newbie de base.
MERCI
vraiment
MERCI
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
no problem
Users browsing this forum: Google [Bot] and 14 guests
