Page 1 of 1
Posted: 20 Mar 2011, 20:47
by héliouk 6
it's a workspace where i change the tempo;i send a 130 value to master sync,but it's a value as 130,03 or 129,88,not 130.the same for others (3 different tempi)
why?
Posted: 20 Mar 2011, 21:22
by nay-seven
What do you use to send this value...?
have you tried to insert a math/ trunc module before the tempo inlet..?
Posted: 21 Mar 2011, 12:05
by grego mondo
Hello Héliouk,
Does your master tempo receive 130,03 or does it receive 130 and become 130,03 ?
Check your "perfect synchro" option in set up ... try to desactivate it and your master synchro should be 130 if it received 130 ...
see you
Posted: 21 Mar 2011, 12:55
by senso
for info : to avoid this behavior, disable the 'perfect synchro' option in the Setup/Asio panel.
Posted: 22 Mar 2011, 00:02
by héliouk 6
thanks a lot guys!
i was sending integer value,but now (with perfect syncro off!) ,it' ok.
amazing no?
Posted: 22 Mar 2011, 00:19
by grego mondo
As far as I understood, the "Perfect Synchro" is related to the buffer size of your sound card, so 130,03 bpm was a multiple of your buffer size and 130 was not a multiple, so tempo goes to the nearest bpm multiple ...
hope I'm clear ...
see you
Posted: 22 Mar 2011, 11:02
by héliouk 6
yes it's clear...i didn't know about that
thanks mister mondo.
see you
