Hola !
I write a patch in the sequencer call "patch 1" in a work space call "WS1"
there's a user curve link to this patch for the volume.
I can see my usercurve in the seq.
everything works fine.
I save my "patch 1"
Now I open a new Workspace.
I insert my "patch 1" in the sequencer
But I don't see my usercurve anymore !
Is there a way to store my original usercurve in a patch ?
if not, where are the usercurve data stored
Best regards
j.
Sequencer - user curve and patch
Hola hombre !
no, senso can maybe confirm but the user curves are store with the sequencer in the workspace, can't be saved in a patch
here a workaround, maybe others solution :
use a lines module inside your patch , set his length the same as your patch in the sequence,set his synchro on button, and use an on activation module to start it...this way you can save your patch.:
gracia !
interessant ! so the datas for the usercurve are in the workspace.
I like also the way you solve it
very elegant
very elegant
Users browsing this forum: No registered users and 159 guests
